Possible IDE for rtems OS
Silverio Diquigiovanni silverio.di at qem.it
Fri Jun 8 06:39:06 UTC 2001
Ralf Corsepius wrote:
> > Silverio Diquigiovanni wrote:
> > > http://www.bloodshed.net/devcpp.html
> Can't comment on this one (Win-only is not acceptable for me).
Actually this is right, only a Windows version is available, but program
is wrote with pascal Delphi 5 from Borland. By few months Borland has
released a delphi IDE for Linux, called Kylix, which seem be full compatible
with new Delphi 6 for Windows. Then I aspect to see the porting of DevCpp
in either OS. The point is:
- could be possible to modify the IDE and put it RTEMS knowledge.
  I think to special dialogs in which set the RTEMS parameters like:
  task number, initial task properties, staks, list of module to link,
  choice of cpu & target (BSP), number of messages, and so on...
- could be possible to modify the make file generator to accomplish
  RTEMS's make files.
- could be possible to insert special monitor, outside from gdb, check
  the target (by rom monitor stub) the task status, memory and so on...
But, perhaps, I dream too much....
> Some time ago I also tried
> * Code-Crusader ($$$) - Look-and-Feel resembles to kdevelop, leaner
> than kdevelop, poor performance.
Yes, this is my first IDE used with RTEMS. It has few functionality and the
debug facilities is also more poor. Nice the graphical impact...
> * SourceNavigator (formerly $$$$, now GPL) - good performance wrt.
> large source-tree, fits nicely into RTEMS.
> Some versions have stability issues, developement appears to be more
> or less frozen, supported hosts: Unix and Win, tcl/tk based.
> You might have guessed it: Outside of the RTEMS project, I am
> sometimes using SourceNavigator. Due to the large number of files in
> RTEMS, the overhead all these tools impose, is hardly acceptable for
> me.
I agree. I use source navigator 5.0 for Windows with GNU tool chain for
Hitachi SH2 (7045F) in alternation at the Green Hills SH IDE. The Windows
version seem be stable but much slow. Sincerely the GNU compiler get code
lightly more fast than Green Hills compiler but with fixed math & floating
point
its quality decrease incredibly. Thus I use SN & GNU tools only for marginal
projects...
However, bye all
