ppcn_60x BSP question
Fri Jun 8 12:43:16 UTC 2001
OUTWATER ~ KEITH J /5G3110 wrote:
> I'm considering using the ppcn_60x BSP as a basis for the console and interrupt
> portions of a generic mpc750 BSP.  I only need a console port interrupt and a
> decremented interrupt.  I'm using the ns16550 driver in libchip.
> The ppcn_60x BSP interrupt support code seems a little more suited to what I'm
> trying to do than the MCP750 BSP interrupt code.
> Does anyone know of any issues related to the ppcn_60x BSP that wuld make using
> its interrupt handlers a problem?
It along with the other BSPs I will mention all use the old exception
processing model.  Long-term, I would like to see it superceded.
AFAIK The ppcn_60x hasn't been run on real HW in a long time. :)
The score603e BSP is similar but at least sometimes gets tested.  The
dmv177
is the original BSP that libchip was used on.
> Thanks,
> Keith
