bus master dma help from DMA expert requested
mike varga mike.varga at caveonetworks.com
Fri Jun 15 01:30:37 UTC 2001
I am trying to do Bus master DMA from
my board to the Host memory.
I have noticed that my boards PCI
bridge chip, where the dma engines
are located, does not specify the PCI device
but only the PCI bus when programming for
DMA from/to the host.
Is this common? Is it assumed that
a DMA initiated from an RTOS from/to
host memory is a default when going
to the pci bus? Could I be reading the
documentation wrong?
I am using the Hurricane
with a Vcubed v320USC
bridge chip.
Thanks
URL: <http://lists.rtems.org/pipermail/users/attachments/20010614/f26d2162/attachment.html>
