use pppd
Stan
zylog at club-internet.fr
Sun Nov 25 20:38:34 UTC 2001
----- Original Message -----
To: Stan
Cc: rtems-users at oarcorp.com
Sent: Tuesday, November 13, 2001 8:29 PM
Subject: RE: use pppd
Hi Stan,
The best place to look is at the example code in the pppd directory under
the latest snapshot.
I use RTEMS 4.5.0, did you have an example for that ?
The only difference between using a serial port vs. a modem is that you need
to set up the chat program/function dialing scripts. These scripts send different
strings to the modem.
All right.
Thanks.
Stan.
Good Luck
Mike Siers
-----Original Message-----
Sent: Tuesday, November 13, 2001 12:13 PM
To: rtems-users at oarcorp.com
Subject: use pppd
hello,
What are the different steps for use a pppd ?
1 - over tty
2 - over modem
Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20011125/141d23f7/attachment-0001.html>
