use pppd
Mike Siers mikes at poliac.com
Mon Nov 26 15:00:41 UTC 2001
Hi Stan,
No, pppd is only available in the newer snapshots.
Mike Siers
  -----Original Message-----
  Sent: Sunday, November 25, 2001 2:39 PM
  To: Mike Siers
  Cc: rtems-users at oarcorp.com
  Subject: Re: use pppd
    ----- Original Message -----
    To: Stan
    Sent: Tuesday, November 13, 2001 8:29 PM
    Subject: RE: use pppd
    Hi Stan,
    The best place to look is at the example code in the pppd directory
under
    the latest snapshot.
  I use RTEMS 4.5.0, did you have an example for that ?
    The only difference between using a serial port vs. a modem is that you
need
    to set up the chat program/function dialing scripts.  These scripts send
different
    strings to the modem.
   All right.
  Thanks.
  Stan.
    Good Luck
    Mike Siers
      Sent: Tuesday, November 13, 2001 12:13 PM
      To: rtems-users at oarcorp.com
      Subject: use pppd
      hello,
      What are the different steps for use a pppd ?
      1 - over tty
      2 - over modem
      Thanks.
URL: <http://lists.rtems.org/pipermail/users/attachments/20011126/d3d06260/attachment-0001.html>
