problems adding targets to libfs
Joel Sherrill
joel at OARcorp.com
Tue Nov 27 20:37:30 UTC 2001
Matthew J Fletcher wrote:
> Hi,.
> I've been trying to add a new filesystem into libfs but have gotten pretty
> stuck in rtems quite impressive build system,.. :)
> [ not very helpfull error message ]
> Making all in wrapup
> gmake[4]: Entering directory `/xfs/rtems-build/c/posix/libfs/wrapup'
> gmake[4]: *** No rule to make target `../src/jffs/o-optimize/libjffs.a',
> needed by `o-optimize/libfs.a'. Stop.
With one exception, the stuff in your patch appears OK at 1st glance.
My reading of the diff is that it is backwards. :)
The remaining questions are:
1. Did you run bootstrap in the libfs directory?
2. Did the make descend into src/jffs?
3. Did it create the src/jffs/o-optimize/libjffs.a file? Is it there?
4. For whatever reason, did you try a rebuild from scratch just in
case?
I assume there is not a typo in the name libjffs.a. :)
Is this the Linux JFFS? And did the licensing question get resolved?
--joel
> the error seems to be that the directory (and files) within
> 'rtems-ss-20011025/c/src/libfs/jff' were not copied across
> to 'rtems-build/c/posix/libfs/jffs' i.e no attempt was made to create the
> directory.
> as with other autoconf / automake based systems i have edited
> the following files,.
> /libfs/src/Makefile.am // added extra subdir
> /libfs/src/wrapup/Makefile.am // added extra lib to libfs
> /libfs/configure.ac // added extra makefile
> so the question is what am i missing ?
> for some more details on what i did i have included a [ edited ] patch
> of my build efforts,..
> [ - patch begins - ]
> diff -ru2 ./rtems-ss-20011025/c/src/exec/sapi/include/confdefs.h
> ./rtems-ss-20011025-clean/c/src/exec/sapi/include/confdefs.h
> --- ./rtems-ss-20011025/c/src/exec/sapi/include/confdefs.h Mon Nov 26
> 10:22:50 2001
> +++ ./rtems-ss-20011025-clean/c/src/exec/sapi/include/confdefs.h Tue Oct 16
> 20:05:28 2001
> @@ -104,5 +104,4 @@
> #include <imfs.h>
> -#include <jffs.h> /* mjf - 28/11/2001 - added initial jffs filesystem */
> #ifdef CONFIGURE_INIT
> @@ -112,6 +111,4 @@
> #ifdef CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> &IMFS_ops,
> -#elif CONFIGURE_USE_JFFS_AS_BASE_FILESYSTEM /* mjf - using jffs as base
> filesystem */
> - &JFFS_ops,
> #else /* using miniIMFS as base filesystem */
> &miniIMFS_ops,
> diff -ru2 ./rtems-ss-20011025/c/src/libfs/configure.ac
> ./rtems-ss-20011025-clean/c/src/libfs/configure.ac
> --- ./rtems-ss-20011025/c/src/libfs/configure.ac Mon Nov 26 10:07:17 2001
> +++ ./rtems-ss-20011025-clean/c/src/libfs/configure.ac Fri Oct 12 19:44:57
> 2001
> @@ -33,5 +33,4 @@
> src/Makefile
> src/imfs/Makefile
> -src/jffs/Makefile
> wrapup/Makefile
> diff -ru2 ./rtems-ss-20011025/c/src/libfs/src/Makefile.am
> ./rtems-ss-20011025-clean/c/src/libfs/src/Makefile.am
> --- ./rtems-ss-20011025/c/src/libfs/src/Makefile.am Wed Nov 21 22:09:38 2001
> +++ ./rtems-ss-20011025-clean/c/src/libfs/src/Makefile.am Wed Oct 18 19:10:55
> 2000
> @@ -5,7 +5,5 @@
> AUTOMAKE_OPTIONS = foreign 1.4
> -SUBDIRS = imfs jffs
> -# mjf - 21/11/2001 - added jffs
> +SUBDIRS = imfs
> include $(top_srcdir)/../../../automake/subdirs.am
> Only in ./rtems-ss-20011025/c/src/libfs/src: jffs
> diff -ru2 ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.am
> ./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.am
> --- ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.am Mon Nov 26 09:27:46
> 2001
> +++ ./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.am Wed Oct 18
> 19:10:55 2000
> @@ -16,10 +16,5 @@
> #endif
> -# mjf - 21/11/2001 - added jffs support
> -#if HAS_JFFS
> -JFFSLIB = ../src/jffs/$(ARCH)/libjffs.a
> -#endif
> -TMP_LIBS = $(IMFSLIB) $(JFFSLIB)
> +TMP_LIBS = $(IMFSLIB)
> $(PROJECT_RELEASE)/lib/$(LIBNAME)$(LIB_VARIANT).a: $(LIB)
> diff -ru2 ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.in
> ./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.in
> --- ./rtems-ss-20011025/c/src/libfs/wrapup/Makefile.in Wed Nov 21 22:15:33
> 2001
> +++ ./rtems-ss-20011025-clean/c/src/libfs/wrapup/Makefile.in Thu Oct 25
> 23:03:49 2001
> @@ -245,12 +245,7 @@
> #if HAS_IMFS
> IMFSLIB = ../src/imfs/$(ARCH)/libimfs.a
> -#endif
> -# if HAS_JFFS
> #endif
> PROJECT_TOOLS = $(PROJECT_RELEASE)/build-tools
> diff -ru2 ./rtems-ss-20011025/c/src/libmisc/shell/cmds.c
> ./rtems-ss-20011025-clean/c/src/libmisc/shell/cmds.c
> --- ./rtems-ss-20011025/c/src/libmisc/shell/cmds.c Mon Nov 26 10:28:36 2001
> +++ ./rtems-ss-20011025-clean/c/src/libmisc/shell/cmds.c Thu Aug 9 23:08:45
> 2001
> @@ -44,5 +44,4 @@
> #include <imfs.h>
> -#include <jffs.h> /* mjf - 28/11/2001 - jffs filesystem support - mkfs.jffs
> #include <rtems/shell.h>
> [ - patch ends - ]
> regards
> Matthew J Fletcher amimjf at connectfree.co.uk
> Software Engineering Matthew.Fletcher at student.shu.ac.uk
> www.amimjf.org ICQ amimjf 44193496
> Since when did ignorance become a point of view ??
