PPP via message queues
Fernando RUIZ CASAS (E-mail)
fernando.ruiz at ctv.es
Tue Oct 23 13:07:06 UTC 2001
You have a telnet daemon in RTEMS.
You can start a telnet session for a tcp/ip conection.
The pty driver (a very particular implementation) is builded in
libnetworking/rtems_telnetd. Perhaphs anything there can help you.
Any question about this?
Fernando RUIZ CASAS
home:correo at fernando-ruiz.com
work:fernando.ruiz at ctv.es
> -----Mensaje original-----
> De: gregory.menke at gsfc.nasa.gov [mailto:gregory.menke at gsfc.nasa.gov]
> Enviado el: lunes, 22 de octubre de 2001 21:05
> Para: RTEMS mailing list
> Asunto: PPP via message queues
> Hi,
> Our application sources and sinks a serial stream which we'd like to
> hook up to the RTEMS pppd. From browsing around the PPP tree, I found
> where sys-rtems.c does read() and write(), presumably talking to a
> RTEMS serial device. I'd like to either put a pty in there or a
> message queue. I saw some references in rtemsmain.c to pty support,
> so I'd like to go that way if possible.
> Is there support for pty-like things in RTEMS? And if so, any hints
> about where to look for them would be much appreciated.
> Thanks,
> Greg Menke
