information about resources of actual application
Jan.Suchotzki at de.abb.com
Fri Sep 28 15:10:31 UTC 2001
Hi,
Chris Johns wrote:
>I think I understand what you are asking.
>If you check the top of the rtems/config.h file you will find a macro
>called "rtems_resource_unlimited". When you define your object counts
>for the configuration table via confdefs.h do :
>#define CONFIGURE_MAXIMUM_TASKS rtems_resource_unlimited (5)
>#define CONFIGURE_MAXIMUM_TIMERS rtems_resource_unlimited (10)
>#define CONFIGURE_MAXIMUM_SEMAPHORES rtems_resource_unlimited (10)
>#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES rtems_resource_unlimited (5)
>You will be able to create an many tasks, timers, semaphores and
>messages limited only by the Work Space memory you have allocated. The
>size parameter is the allocation unit used. At initialisation the
>allocation unit number of objects is allocated from the Work Space.
Yes, this seems to be very helpful. But I´m not sure if I understood the
part with the size right.
Is it correct, that in your example 5 tasks will be allocated while
initialisation,
but I can use even more?
> Chris Johns, cjohns @ cybertec.com.au
Jan Suchotzki
