Power awareness
Bill Butler billb at tnex.com
Fri Apr 19 13:50:10 UTC 2002
Joel,
I have tried for the past 2 days to use the user list archive search
engine and get a failure message when searching (Internal Server Error).
I have tried it under Explorer/2000 and Netscape/linux with the same
results.
Is it something on my end or Oarcorp?
Thanks
Bill Butler
AIPCom Inc
972-644-2328 x16
bbill at tnex.com
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
Sent: Friday, April 19, 2002 6:33 AM
To: Harvey Tuch
Cc: rtems-users at oarcorp.com
Subject: Re: Power awareness
Harvey Tuch wrote:
> Hi,
> I was wondering if anyone has done any work on power
awareness/management/
> efficiency on RTEMS (e.g. dynamic voltage scheduling, accounting, API
issues)? I
> gather some has been done on eCos, but I haven't seen anything on
RTEMS.
> I'm looking for an area to do a thesis at the moment, and I am
considering
> doing this, but I do not wish to duplicate existing work.
There is no variable power management capability right now but there is
a place to insert a switch to idle/low power mode.  Some CPUs and BSPs
have a special version of the IDLE task which puts the CPU in a low
power
state.  But there is nothing that says we are only 10% CPU utilization
so
lower the clock rate.
> Thanks,
> Harvey
> Harvey Tuch
htuch at cse.unsw.edu.au
