htdig was Re: Power awareness
Fri Apr 19 14:56:17 UTC 2002
Jeff.. it looks like there is an htdig problem since
upgrading www.  COuld you look into it please?
Thanks.
--joel
Bill Butler wrote:
> Joel,
> I have tried for the past 2 days to use the user list archive search
> engine and get a failure message when searching (Internal Server Error).
> I have tried it under Explorer/2000 and Netscape/linux with the same
> results.
> Is it something on my end or Oarcorp?
> Thanks
> Bill Butler
> AIPCom Inc
> 972-644-2328 x16
> bbill at tnex.com
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at OARcorp.com]
> Sent: Friday, April 19, 2002 6:33 AM
> To: Harvey Tuch
> Cc: rtems-users at oarcorp.com
> Subject: Re: Power awareness
> Harvey Tuch wrote:
> > Hi,
> > I was wondering if anyone has done any work on power
> awareness/management/
> > efficiency on RTEMS (e.g. dynamic voltage scheduling, accounting, API
> issues)? I
> > gather some has been done on eCos, but I haven't seen anything on
> RTEMS.
> > I'm looking for an area to do a thesis at the moment, and I am
> considering
> > doing this, but I do not wish to duplicate existing work.
> There is no variable power management capability right now but there is
> a place to insert a switch to idle/low power mode.  Some CPUs and BSPs
> have a special version of the IDLE task which puts the CPU in a low
> power
> state.  But there is nothing that says we are only 10% CPU utilization
> so
> lower the clock rate.
> > Thanks,
> > Harvey
> > Harvey Tuch
> htuch at cse.unsw.edu.au
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel at OARcorp.com                 On-Line Applications Research
>    Support Available             (256) 722-9985
