Any news on GCC 3+ and GNAT/RTEMS?
VALETTE Eric valette at crf.canon.fr
Thu Aug 22 09:08:48 UTC 2002
Ralf Corsepius wrote:
> There should be rpms somewhere at ftp.oarcorp.com.
I use a non rpm based distribution.
> If wanting to build them yourselves:
> untar RTEMS's source tarball
> and
> cd rtems-<version>/scripts
> ./configure --prefix=/opt/rtems
> make
> cd autotools
> rpm -ba autoconf-rtems.spec
> [become root if necessary]
> rpm -U <path>/autoconf-rtems-<version>.noarch.rpm
> rpm -ba automake-rtems.spec
> rpm -U <path>/automake-rtems-<version>.noarch.rpm
> Afterwards make sure to have set
> PATH=/opt/rtems/bin:$(PATH)
> if working at RTEMS.
Ralf,
First thanks for responding. Then unfortunately, as I'm not a
autoconf/automake expert, I do not understand what you suggest + I use a
non RPM based linux distribution (OK I have converter but If I want to
compile a solaris host I will not have rpm...).
So first question that comes in mind and make be inrelevant : do you
have specific rtems patch for the autoconf or automake software or can I
install the regular distribution?
Next question is what are the command you have documented supposed to do
(if I have no rpm command, I must make it differently and understand
what really needs to be done).
Thanks for your patience,
    __
   /  `                          Eric Valette - Canon CRF
  /--   __  o _.                 Product Dev. Group Software Team Leader
(___, / (_(_(__                 Rue de la touche lambert
                                 35517 Cesson-Sevigne  Cedex
                                 FRANCE
Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
