Problems with GCC for ARM
Jay Monkman
jtm at smoothsmoothie.com
Wed Dec 18 18:12:21 UTC 2002
I tried these with the two compilers I have:
gcc-2.95.3, dated 20010315
gcc-3.2.1, dated 20021203
> http://gcc.gnu.org/ml/gcc-bugs/2000-06/msg00705.html
Didn't happen with either.
> http://gcc.gnu.org/ml/gcc-bugs/2002-08/msg00100.html
Happened with 2.95.3, but not 3.2.1. However if I use -O3, it doesn't
happen - most of the code is optimized away.
> http://gcc.gnu.org/ml/gcc-help/2002-11/msg00168.html
This looks like a repeat of the previous one, but no test code to
test.
> http://www.geocrawler.com/archives/3/356/2000/9/50/4412642
Again, no test code, but I'm guessing it's the same as the first test
above.
We've been using 2.95.3 for our development, but we use -O3.
I just looked through most of our builds for a 'tst' instruction
followed by an instruction that sets the condition registers, and
couldn't find any.
We've got a bunch of systems in use and I don't think we've run into
any erratic behavior that isn't our fault. With a different
application, that statement might not hold, though.
Jay Monkman The truth knocks on the door and you say "Go away, I'm
looking for the truth," and so it goes away. Puzzling.
- from _Zen_and_the_Art_of_Motorcycle_Maintenance_
