New user questions
Chris Johns
cjohns at cybertec.com.au
Thu Feb 14 02:15:55 UTC 2002
Mike Panetta wrote:
> I am new to RTEMS, and I had a few, possibly simple questions. I have
> read some of the documentation on line, but it does not seem to answer
> my particular question.
> The first question is not really related to RTEMS in itself but to the
> list. Are there any list archives that I can search through? It seems
> there were at one point, but the link is broken now.
> The second question is this: Is there a way to do something similar to
> setjmp/longjmp from a fault signal handler (say like a SIGBUS handler
> for example), but from an rtems ISR? I am writing a piece of code that
> I want to be able to let recover from a bus error, but I am not quite
> sure how to do it in RTEMS using an ISR. I know how to set up the ISR,
> but I am not quite sure how to do the context save/restore for the task
> that I want to recover. Does such a facility exist in RTEMS? If not,
> what would be involved to get this idea to work? Is it even a good
> idea? ;) The basic idea is I have a VME rack, that may or may not have a
> memory card at a particular address, and if its not there I want it to
> gracefully recover from the bus error thats generated. Having something
> like setjmp/longjmp for this would be great, because I could save the
> task context before I do the bus op that may fail, and if it does I can
> get notification via the return value of the "setjmp" function, which
> would also restore the task back to the place it was before it failed.
I have code to do this for m68k targets. It uses setjmp/longjmp. Its
make a simple means of probing hardware.
I attach the start of the API for RTEMS. A header file called probe.h
needs to be created and add to the rtems include tree. Maybe Joel can
help here. I currently have the CPU_probe_exception_* hooks in a
separate C file for the m68k family. These could be inlined in the cpu.h
file for the specific processor.
In time the way the probes are implemented may. A machine check of any
form should result in the task being suspended rather than RTEMS stopping.
I hope this helps.
Chris Johns, cjohns at cybertec.com.au
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020214/bde5c056/attachment-0001.obj>
