gnu tools update
Eric Norum
eric.norum at usask.ca
Mon Feb 25 16:40:29 UTC 2002
Joel Sherrill wrote:
> gcc 3.0.4 was released. It should include all necessary RTEMS
> patches. The only issue is a minor one of using a deprecated
> form of something internal in a couple of target specific files.
> Not all RTEMS targets that built for 2.95.x build. I only
> build and report on C/C++.
Two steps forward, one step back....
I picked up gcc-3.0.4, configured it with:
../gcc-3.0.4/configure --target=i386-rtems --prefix=/opt/rtems
--with-gnu-as --with-gnu-ld --with-newlib --enable-threads
--enable-languages=c,c++
then ran `gmake -w' and after a while got:
gmake[1]: Leaving directory `/usr/local/source/RTEMS/tools/build/gcc'
Configuring in i386-rtems/newlib
Created "Makefile" in
/usr/local/source/RTEMS/tools/build/i386-rtems/newlib
/opt/rtems/i386-rtems/bin/ld: cannot open crti.o: No such file or
directory
collect2: ld returned 1 exit status
*** The command '/usr/local/source/RTEMS/tools/build/gcc/xgcc
-B/usr/local/source/RTEMS/tools/build/gcc/ -nostdinc
-B/usr/local/source/RTEMS/tools/build/i386-rtems/newlib/ -isystem
/usr/local/source/RTEMS/tools/build/i386-rtems/newlib/targ-include
-isystem /usr/local/source/RTEMS/tools/gcc-3.0.4/newlib/libc/include
-B/opt/rtems/i386-rtems/bin/ -B/opt/rtems/i386-rtems/lib/ -isystem
/opt/rtems/i386-rtems/include -o conftest -g -O2 conftest.c' failed.
*** You must set the environment variable CC to a working compiler.
gmake: *** [configure-target-newlib] Error 1
When I configure and build for --target=m68k-rtems the above error does
not occur. There's a warning at the same point:
Configuring in m68k-rtems/newlib
/usr/local/source/RTEMS/tools/build/m68k-rtems/newlib
/opt/rtems/m68k-rtems/bin/ld: warning: cannot find entry symbol _start;
defaulting to 8000007c
but it doesn't seem to cause any problems.
> gcc 3.1 branch should be cut shortly. There are no known
> RTEMS patches for that. The state is better that 3.0. I still
> only build and report on C/C++. The target release date is in
> a "couple of months".
Except that as of today the compiler still gets a fatal internal error
when trying to compile libgcc2.c with -msoft-float for i386 targets....
> binutils 2.12 should be out any day. I tested and reported
> test results on 40 targets. No RTEMS patches needed.
Good.
> newlib 1.10.0 is out and requires a couple of minor patches that
> actually are not RTEMS specific. :)
> There are no immediate plans for 1.10.1.
Not so good. I would have thought that a generic problem like that
would trigger a x.x.1 release quite quickly.
Eric Norum eric.norum at usask.ca
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
