Revisied adding a bsp was: Re: adding a bsp
D. Peter Siddons siddons at bnl.gov
Tue Jul 2 12:49:43 UTC 2002
Hi Paul,
    Yes, that just about sums it up. The only addition I would make
would be to reinforce that bootstrap seems to be very dependent on
particular releases of automake and autoconf. It was only after trying
various versions that I finally found and downloaded the ones in the OAR
ftp site. Only then would bootstrap complete successfully. Also, you
definitely need the --enable-maintainer-mode flag in the configure step
so that all gets updated.
Pete.
Paul Evans wrote:
> Hi,
> Ugh. Sorry for the half baked reply everyone (baked Alaska in a
> microwave?). Apparently  Outlook's "Send later" didn't.
> As I recall, my steps were (more verbosely I hope):
> 1. Copy an exists BSP subdirectory to your BSP's name (I used gen68302)
>  e.g. cd rtems-4.5.0/c/src/lib/libbsp/m68k; cp -R ./gen68302 ./mynewbsp
> 2.  Copy the cfg file in the rtems-4.5.0/make/custom directory
> e.g. cd rtems-4.5.0/make/custom ; cp gen68302.cfg mynewbsp.cfg
> 3.Edit cfg file appropriately, specifically for me this included:
>    * change RTEMS_BSP_FAMILY to mynewbsp
>    * check -soft-float in CPU_FLAGS
>    * modify make-exe to append initialized data to image (as per BSP docs)
> and add objcopy
>     command to create a final s-record file.
> 4. Run ../../../../../../bootstrap -c in new BSP directory (get rid of old
> BSP's automake output)
> 5. The great grep: Replace all occurrences of original BSP name with new
> name. This was a
> help to me but YYMV..
> 6. Add/remove BSP leaf directories depending on drivers. (modify Makefile.am
> in BSP root
> to reflect this)
> 7. Machete out (gusto required) code not pertinent to your BSP . (like
> libchip includes or
> use of termios if you don't want it)
> 8. Decide whether pulling in shared BSP parts is applicable  and do so.
> (Also do the same with libchip.)
> 9. Re-run bootstrap
> 10. Run configure/make etc. (make sure target more or less compiles)
> 11. Now, (obviously) customize as required (and rerun boostrap if make data
> is modified)
> 12. Rinse and repeat. (FYI: Don't leave computer on during rinse, I learned
> the hard way)
> Hope this helps,
>     -Paul
> > copy an exists bsp subdirectory to your bsps name (I used gen68302)
> > copy the cfg file in the build directory
> ----- Original Message -----
> From: "Paul Evans" <paule at martex.gen.oh.us>
> To: <siddons at bnl.gov>; <rtems-users at oarcorp.com>
> Sent: Monday, July 01, 2002 12:17 PM
> Subject: Re: adding a bsp
> > From my personal experience the steps were
> > From: "D. Peter Siddons" <siddons at bnl.gov>
> > To: <rtems-users at oarcorp.com>
> > Sent: Friday, June 28, 2002 9:33 AM
> > Subject: adding a bsp
> > > Hi all,
> > >     What is the proper way to add a BSP? Although the requirements for
> > > creating the BSP files are well covered in the documentation, I couldn't
> > > see how to integrate this new subdirectory into the build system. Does
> > > this rely on Autoconf? if so, what needs to be changes in the config.ac
> > > files. If not, how to proceed?
> > > Pete.
> > > D. Peter Siddons
> > > National Synchrotron Light Source, Bldg. 725D
> > > Brookhaven National Laboratory
> > > Upton
> > > New York 11973
> > > Email: siddons at bnl.gov
D. Peter Siddons
Upton
New York 11973
