Revisied adding a bsp was: Re: adding a bsp
Paul Evans paule at martex.gen.oh.us
Tue Jul 2 15:46:37 UTC 2002
Your comment about auto(make|conf) is spot on. I gave up entirely on Solaris
8 with autoconf 2.52 and a couple older ones (which I can't recall the
versions
of but think 2.12 was one of them) RedHat 7.2's stock Autoconf 2.13 works
well for me. I'm still befuddled about why I couldn't get anything going on
Solaris though..
    -Paul
----- Original Message -----
To: "Paul Evans" <paule at martex.gen.oh.us>
Cc: <rtems-users at oarcorp.com>
Sent: Tuesday, July 02, 2002 8:49 AM
Subject: Re: Revisied adding a bsp was: Re: adding a bsp
> Hi Paul,
>     Yes, that just about sums it up. The only addition I would make
> would be to reinforce that bootstrap seems to be very dependent on
> particular releases of automake and autoconf. It was only after trying
> various versions that I finally found and downloaded the ones in the OAR
> ftp site. Only then would bootstrap complete successfully. Also, you
> definitely need the --enable-maintainer-mode flag in the configure step
> so that all gets updated.
> Pete.
> Paul Evans wrote:
> > Hi,
> > Ugh. Sorry for the half baked reply everyone (baked Alaska in a
> > microwave?). Apparently  Outlook's "Send later" didn't.
> > As I recall, my steps were (more verbosely I hope):
> > 1. Copy an exists BSP subdirectory to your BSP's name (I used gen68302)
> >  e.g. cd rtems-4.5.0/c/src/lib/libbsp/m68k; cp -R ./gen68302 ./mynewbsp
> > 2.  Copy the cfg file in the rtems-4.5.0/make/custom directory
> > e.g. cd rtems-4.5.0/make/custom ; cp gen68302.cfg mynewbsp.cfg
> > 3.Edit cfg file appropriately, specifically for me this included:
> >    * change RTEMS_BSP_FAMILY to mynewbsp
> >    * check -soft-float in CPU_FLAGS
> >    * modify make-exe to append initialized data to image (as per BSP
docs)
> > and add objcopy
> >     command to create a final s-record file.
> > 4. Run ../../../../../../bootstrap -c in new BSP directory (get rid of
old
> > BSP's automake output)
> > 5. The great grep: Replace all occurrences of original BSP name with new
> > name. This was a
> > help to me but YYMV..
> > 6. Add/remove BSP leaf directories depending on drivers. (modify
Makefile.am
> > in BSP root
> > to reflect this)
> > 7. Machete out (gusto required) code not pertinent to your BSP . (like
> > libchip includes or
> > use of termios if you don't want it)
> > 8. Decide whether pulling in shared BSP parts is applicable  and do so.
> > (Also do the same with libchip.)
> > 9. Re-run bootstrap
> > 10. Run configure/make etc. (make sure target more or less compiles)
> > 11. Now, (obviously) customize as required (and rerun boostrap if make
data
> > is modified)
> > 12. Rinse and repeat. (FYI: Don't leave computer on during rinse, I
learned
> > the hard way)
> > Hope this helps,
> >     -Paul
> > > copy an exists bsp subdirectory to your bsps name (I used gen68302)
> > > copy the cfg file in the build directory
> > From: "Paul Evans" <paule at martex.gen.oh.us>
> > To: <siddons at bnl.gov>; <rtems-users at oarcorp.com>
> > Sent: Monday, July 01, 2002 12:17 PM
> > Subject: Re: adding a bsp
> > > From my personal experience the steps were
> > > From: "D. Peter Siddons" <siddons at bnl.gov>
> > > To: <rtems-users at oarcorp.com>
> > > Sent: Friday, June 28, 2002 9:33 AM
> > > Subject: adding a bsp
> > > > Hi all,
> > > >     What is the proper way to add a BSP? Although the requirements
for
> > > > creating the BSP files are well covered in the documentation, I
couldn't
> > > > see how to integrate this new subdirectory into the build system.
Does
> > > > this rely on Autoconf? if so, what needs to be changes in the
config.ac
> > > > files. If not, how to proceed?
> > > > Pete.
> > > > D. Peter Siddons
> > > > National Synchrotron Light Source, Bldg. 725D
> > > > Brookhaven National Laboratory
> > > > Upton
> > > > New York 11973
> > > > Email: siddons at bnl.gov
> D. Peter Siddons
> Upton
> New York 11973
