how to load application by rdbg???
David wu rtemswq at yahoo.com.cn
Tue Jul 30 08:41:47 UTC 2002
hello all,
I have modified file /netdemos-4.5.0/netdemo/init.c
adding rtems_rdbg_initialize();
after rtems_bsdnet_initizlize_network();
and then i can run netdemo.exe on target (i386
pc386),remote debug netdemo.exe useing b,c,info
thereads ...command via network,(host is redhat
linux7.2)
but how can i download my host application to
target,and can i change the application runing on the
target easily .
other operations :
i386-RTEMS-gdb netdemo.exe
<gdb>setrpcmode sun
<gdb>setdaemontype rdbg
<gdb>target rtems 192.168.91.21
<gdb>attach 1
Attaching remote machine across net ...
connected to 192.168.91.21
now the "run" command will start a remote process.
[switching to process 134283273]
0x1301f5 in enterRdbg()
<gdb>info thereads
thanks
                   David wu
_________________________________________________________
Do You Yahoo!?
世界杯风云跌宕 网站报道最爱哪家
http://sweepstakes.yahoo.com/fifa_survey
