please review tool versions was [Fwd: Re: Anyone using RTEMS on MPC8260ADS]
Fri Mar 22 12:22:02 UTC 2002
My wife is having surgery today so I think the
fastest way to get a review is to send it here.
My first inclination is that binutils can be updated
to 2.12 w/o patches or 2.11.2 with RTEMS patches.
I would have to look at the specifics with this.
Look at the "LATEST*" links at
ftp://ftp.oarcorp.com/pub/rtems/snapshots/c_tools
--joel
-------- Original Message --------
Subject: Re: Anyone using RTEMS on MPC8260ADS
To: Joel Sherrill <joel.sherrill at OARcorp.com>
So how about the following combination:
autoconf-rtems.2.52.0.src.rpm
automake-rtems-1.5.0.src.rpm
binutils-2.10.tar.gz  with  binutils-2.10-rtems-20001107.diff
gcc-everything-2.95.3.tar.gz with  gcc-2.95.3.-rtems-20010904.diff
gdb-5.0.tar.gz  with gdb-5.0.rtems-20020102.diff
newlib-1.9.0.tar.gz with newlib-1.9.0-rtems-20010622.diff
rtems-ss-20020301.tar.gz
Any chance of the above being the right collection of stuff?  I'm trying
to
build for the mpc8260ads BSP.
At 04:01 PM 3/20/2002 -0600, you wrote:
>Steven Grunza wrote:
> > I just downloaded the rtems-ss-20020301.tar.bz2 snapshot
> > What's the best way to integrate it into my environment?  I'm Unix(TM)
> > based (NetBSD) with powerpc-rtems built and installed currently for
> rtems-4.5.0
>The 4.5 tools are not 100% OK with snapshots.  You can use the same
>binutils
>and gdb but the gcc/newlib needs to come from the snapshot side.  We did
>a
>big reorg of the newlib include files so we could use the shared .h
>files.
>So RTEMS and cygwin largely have the same .h files. :)
>You can use the instructions for configure/make or look at the FreeBSD
>ports packages for the tools.  On a fast machine, it won't take long.
> > > > Is anyone using RTEMS on a Motorola MPC826x processor or even better on
> > > > Motorola's MPC8260ADS?  I haven't found a BSP for the 826x line and
> I've
> > > > heard that the MMU is rather different between the MPC860 and the
> > > > MPC8260.  I may have a loaner 8260ADS for a month or so for running
> some
> > > > benchmarks and I plan to try to use RTEMS as my
> OS/executive.  Thanks for
> > > > any offers of help.
> > >Any snapshot since Oct 22, 2001 will have a BSP for the mpc8260ads.
> > > > I'll be developing code under either SPARC or x86 based systems running
> > > > NetBSD (www.netbsd.org for details on NetBSD) but might not have a OCD
> > > > (on-chip debugger) available.
> > >Can't help much on this myself. :)
> > >Joel Sherrill, Ph.D.             Director of Research & Development
