Re. Building latest snapshot using latest tools fails for m68k Coldfire under cygwin
Jonas Moberg
jonas.moberg at solidsoftware.net
Tue Mar 26 04:59:35 UTC 2002
Probably allready asked by somebody else - but here we go:
When trying to build RTEMS (2002-03-01 snapshot) using the latest tool chain from snapshot
for m68k Coldfire the assembler complains.
The module compiled is fat.c and I guess it origins from some bit-banging code in the FAT implementation.
Pretty shure that the correct as is used.
Working under cygwin.
Any idea?
/Jonas Moberg
make[6]: Entering directory `/cygdrive/c/rtems/m68k-ss/m68k-rtems/c/mcf5206elite/libfs/src/dosfs'
m68k-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../mcf5206elite/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H
-I. -ansi -fasm -O4 -fomit-frame-pointer -g -Wall -m5200 -o o-optimize/fat.o -c /cygdrive/c/rtems/rtems-ss-200
20301/c/src/libfs/src/dosfs/fat.c
/cygdrive/c/rtems/rtems-ss-20020301/c/src/libfs/src/dosfs/fat.c: In function `fat_init_clusters_chain':
/cygdrive/c/rtems/rtems-ss-20020301/c/src/libfs/src/dosfs/fat.c:537: warning: implicit declaration of function `fat_get_fat_cluster'
{standard input}: Assembler messages:
{standard input}:3627: Error: invalid instruction for this architecture; needs 68000 or higher -- statement `rorw #8,%d0' ignored
{standard input}:3637: Error: invalid instruction for this architecture; needs 68000 or higher -- statement `rorw #8,%d0' ignored
{standard input}:3655: Error: invalid instruction for this architecture; needs 68000 or higher -- statement `rorw #8,%d1' ignored
{standard input}:3665: Error: invalid instruction for this architecture; needs 68000 or higher -- statement `rorw #8,%d1' ignored
URL: <http://lists.rtems.org/pipermail/users/attachments/20020326/22646ca3/attachment.html>
