Still problems with ELF files
SMIALEK Yan Yan.SMIALEK at criltechnology.com
Tue Mar 26 09:10:41 UTC 2002
Hello,
I was told that output files compiled with the 'ppcn_60x' BSP are in ELF
format.
Using SDS SingleStep, I tried to change the GCC option '-g' with '-gdwarf' ,
'-gdwarf+' , '-gdwarf-2' , '-gstabs' , '-gstabs+'
But I still don't have any source code in the SDS debugger (I tested SDS
with other not RTEMS ELF files and SDS works).
Do you know if the output files normally ended with a EXE extension, are in
fact really in ELF format ?
Do you have any suggestions ?
Thank you !
Yan
