Is there any Guru who knows why interrupts are disabled in ISR?
VALETTE Eric valette at crf.canon.fr
Fri Mar 8 08:41:00 UTC 2002
Leon Pollak wrote:
> Hello Gurus,
>         I shall be very thankful for the explanation of the following moment:
>         I look into PPC code file irq_stub.S routine __ISR_handler I see that
> all
> interrupts are disabled almost immediatly. They are reenabled at the end of
> the ISR, after the user ISR has finished its processing, almost at the point
> of exit from __ISR_handler.
>         This text contains the comment after the _ISR_NestLevel incrementing:
> "From here on out, interrupts can be re-enabled, RTEMS convention says not".
>         Can somebody explain me why interrupts must be disabled inside the
> user ISR?
> Thanks.
Just a side remark : you speak about a processor or even BSP specific
implementation without mentionning it. Besides and because I rewrote the
code for i386/pc386 and powerpc (new_exception_handling), what you say
is false for those platfor ISR are reanabled at processor level almost
immediately after around 5 intructions and latter at PIC/SIU level...
but before caling the handler...
    __
   /  `                          Eric Valette - Canon CRF
  /--   __  o _.                 Product Dev. Group Software Team Leader
(___, / (_(_(__                 Rue de la touche lambert
                                 35517 Cesson-Sevigne  Cedex
                                 FRANCE
Tel: +33 (0)2 99 87 68 91       Fax: +33 (0)2 99 84 11 30
E-mail: valette at crf.canon.fr    http://www.crf.canon.fr
