Bios Calls
Quality Quorum
qqi at theworld.com
Wed Mar 13 03:02:24 UTC 2002
On Wed, 13 Mar 2002, Yan wrote:
> I'm using pc386 bsp.
> Can I call Int 10h to initialize the VGA card with VESA VBE, from within
> RTEMS?
> Vesa documentation says that its possible to make the calls from protected
> mode. Is it true under RTEMS?
PCI code calls PCIBIOS entries without much of the hassle, see files
under shared/pci.
I suppose that you have to read VESA documentation to find out what
do they mean. E.g. if they are talking about DPMI, then I suppose you
are out of luck.
> Thanks
> Yan
Thanks,
Aleksey
