rtems manager
Jan.Suchotzki at de.abb.com
Thu May 2 10:25:18 UTC 2002
Hi,
sorry for this question but what do you mean with stubs?
I would like to figure out the way this feature (inserting managers via
makefile)
is implemented. Does it depend on the autoconf-tools?
Thanks
Jan Suchotzki
(Embedded Joel Sherrill <joel.sherrill at oarcorp.com>
image moved 29.04.2002 16:45
to file:
pic12244.pcx)
Please respond to joel.sherrill at oarcorp.com
To: Jan Suchotzki <jsuchotzki at web.de>
cc: rtems-users at oarcorp.com
Subject: Re: rtems manager
Security Level:? Internal
Jan Suchotzki wrote:
> Hi,
> can someone explain me the concept behind the MANAGER - Variable
> in the Makefile-templates?
> I mean, what happens when I include/exclude managers there?
> How affects it the code-size? Are there special libraries that are linked
> to the code in relation to the MANAGER-Variable?
It replaces the managers you don't want with a stub. In olden days,
it was the only way to significantly reduce code size because all
services within a manager were in a single file. Now the managers
are mostly split up for one function per file and the librarian
and loader take care of only pulling in precisely what is needed.
Check out the symbol table and look for rtems_task. I am sure
there are a lot of services you don't end up including in your
application.
But the stubs are especially useful in that they return E_NOTCONFIGURED
so you can explicitly forbid use of certain managers if that is what
you want to do.
> With kind regards
> Jan Suchotzki
joel at OARcorp.com On-Line Applications Research
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20020502/3091fae3/attachment.obj>
