another, rtems vs rest?
Joel Sherrill
joel.sherrill at OARcorp.com
Tue May 14 11:41:03 UTC 2002
"J.Saravanan" wrote:
> Hi,
> Well, I've a beginners question (in rtos world).
Well since I haven't seen a reply yet, I'll take a quick swing.
> I understand RTEMS is an RTOS and is most suitable for control
> applications. It can be seen that (from mailing list archive) RTEMS can
> also be used for non-RTOS purpose, with a small shell and few applications
> that are statically linked.
Yes.
> My question is, If time is not critical then what prevents from using
> RTEMS as general purpose OS, just like linux. I believe, one cannot link
> too may applications in an RTOS like in general purpose OS. Is that
> correct? Then what is the knee point?
Right now, the lack of dynamic loading is the biggest lacking for
usefulness. There has been work on a dynamic loader but I don't
know the precise status of it at the moment.
The lack of memory protection is a liability but there have
certanly been plenty of general purpose OSes without that.
> (Assuming RTEMS and the rest has all the facilities available, like
> library, etc.)
It has programming libraries but is lacking in graphics
and device driver support in comparison to GNU/Linux.
If you were constructing a PDA based upon RTEMS that would
be OK, since you would settle on a single graphics
standard and hardware configuration but desktop computing
is way too varied.
> Thanks,
> Regards,
> -Saran
joel at OARcorp.com On-Line Applications Research
