pc386 BSP - is it still supported?
Angelo Fraietta
angelo_f at bigpond.com
Sun May 19 07:09:40 UTC 2002
No, I mean the pre built RPMs from the OARCorp site. I'll get the
version numbers I am using tommorrow when I start my Linux machine up.
The pc386dx BSP was added after that release.
Robin Iddon wrote:
> Angelo,
> Thanks for the answer - when you say the "latest linux build tools" do
> you mean the native compiler under Linux, and if so, which version of
> that compiler? Did you rebuild them specially and call them
> i386-rtems-xxx or do you just use /usr/bin/gcc? I find that with the
> latter approach I end up selecting all the wrong header files all the
> time (e.g. termios.h).
> Also I don't see a BSP called pc386dx - is this really just the pc386
> BSP with some CPU= flags set to select the 386dx?
> Will try out the getch() thing too!
> Cheers,
> Robin
> ----- Original Message -----
> From: Angelo Fraietta <mailto:angelo_f at bigpond.com>
> To: Robin Iddon <mailto:robin at iddon.no-ip.com>
> Cc: rtems-users at oarcorp.com <mailto:rtems-users at oarcorp.com>
> Sent: Sunday, May 19, 2002 2:55 AM
> Subject: Re: pc386 BSP - is it still supported?
> I am using that bsp (actually the pc386dx which is identical
> except that it does not use the math co-processor). I am using the
> lastest snapshots with the latest linux build tools. Give it a go
> and see how that works. I used getch (insetad of getc(STDIN) )from
> the PC keyboard a while ago and it worked for me.
> i.e
> char c;
> c = (char) getch();
> See how that goes for you.
> Robin Iddon wrote:
>> Hi,
>> I have tried to use the pc386 BSP with limited success.
>> I started off with the 4.5.0 release, and I could build the BSP
>> and boot it with GRUB onto my target.
>> However, the "unlimited.exe" test appears to fail with hundreds
>> of "thread exceptions" being reported to the console. I tried to
>> add in some "getc(stdin)" to the code to allow me to work out
>> which of the three tests was causing the failure, but they caused
>> it to hang (presumably stdin isn't the PC keyboard).
>> The hello test does work, so it is something a little more subtle
>> than it just not working.
>> Anyway, I noticed that the whole 4.5.0 release is no quite old,
>> so I downloaded the latest snapshot. Unfortunately that doesn't
>> build for the pc386 BSP.
>> I am using the recommended compiler chain running under Linux.
>> Can anyone offer me some advice on what to look for?
>> Thanks in advance,
>> Robin Iddon
>Angelo Fraietta
>PO Box 859
>Hamilton NSW 2303
>Home Page
>http://www.users.bigpond.com/angelo_f/
>There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
>There are those who seek knowledge to be known by others - that is VANITY
>There are those who seek knowledge in order to serve - that is LOVE
> Bernard of Clairvaux (1090 - 1153)
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
URL: <http://lists.rtems.org/pipermail/users/attachments/20020519/c6ef1c59/attachment-0001.html>
