pc386 BSP - is it still supported?
Robin Iddon
robin at iddon.no-ip.com
Sun May 19 07:52:20 UTC 2002
Angelo,
Thanks - no need to worry about the RPM's version numbers - that is what I
am using - just downloaded yesterday.
I still get an error compiling - I use the following configure command:
../rtems-ss-20020301/configure --target=i386-rtems --disable-pos
ix --disable-itron --disable-networking --enable-rtemsbsp=pc386dx
I get the following error message from the compilation:
i386-rtems-gcc --pipe -B../../../../../../../lib/ -B../../../../../../../pc3
86dx/lib/ -specs
bsp_specs -qrtems -DHAVE_CONFIG_H -DUSE_INIT_FINI -ansi -fasm -O4 -g
-Wall -msoft-float -mno-fp-ret-in-387 -o o-optimize/sbrk.o -c
../../../../../../../../../rtems-ss-20020301/c/src/lib/libbsp/i386/pc386/sta
rtup/../../../shared/sbrk.c
rtup/../../../shared/sbrk.c:27: conflicting types for `sbrk'
/opt/rtems/lib/gcc-lib/i386-rtems/2.95.2/../../../../i386-rtems/include/sys/
unistd.h:57: previous declaration of `sbrk'
If you could send me your "configure" command and double check you are using
the same snapshot release, that would be really helpful!
Thanks,
Robin
----- Original Message -----
To: Robin Iddon
Cc: rtems-users at oarcorp.com
Sent: Sunday, May 19, 2002 8:09 AM
Subject: Re: pc386 BSP - is it still supported?
No, I mean the pre built RPMs from the OARCorp site. I'll get the version
numbers I am using tommorrow when I start my Linux machine up.
The pc386dx BSP was added after that release.
