IDE Controller driver, ATA driver, MSDOS-like partition table support
Eugeny S. Mints
Eugeny.Mints at oktet.ru
Fri Oct 11 11:25:48 UTC 2002
Hi, all!
Files atteched are patches for rtems-ss-20020628 and contain IDE
Controller driver and ATA Driver.
Brief documentation for both also attached. (files ata.t ide-ctrl.t)
IDE Controller driver implemented in libchip style. So to start using IDE
and ATA drivers on any real IDE chip you need to implement particular chip
IDE driver. I've attached an example (ide.tar.gz) which I used for testing,
but unfortunately I had non-general custom IDE chip implemented on FPGA, so
it can't be applied directly. In my source tree this 'ide' directory locates
in $RTEMS_SRC_ROOT/c/src/lib/libbsp/sh/mfd because I use custom board
(called mfd) based on sh4 CPU.
It should be noted that unfortunately there was little time for testing, so
I don't think the code is tested well. But I had many successful read/write
and ioctls on real hardware :)
It is recommended to apply the patches as follows:
libblock.patch.diff:
cd $RTEMS_SRC_ROOT/c/src/exec;
patch -p12 -d libblock < libblock.patch.diff
wrapup.patch.diff:
cd $RTEMS_SRC_ROOT/c/src;
patch -p11 -d wrapup < wrapup.patch.diff
libchip.patch.diff
patch -p11 -d libchip < libchip.patch.diff
THen traditional sequence:) - bootstrap, configure, make, make install
Patch to libblock library also contains support for MSDOS-like partition
written by Alexander Kukuta <kam at oktet.ru>. A brief overview is also
presented:)
Of course :), I've already have several ideas how to improve ATA driver, but
ANY FEEDBACKS are highly appreciated, more over that I suspect a bug (but
unfortunately I havn't already caught it:( ) in ATA driver in interrupt mode.
Regards,
Eugeny
Eugeny S. Mints
OKTET Ltd.
1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
Phone: +7(812)428-4384 Fax: +7(812)327-2246
mailto:Eugeny.Mints at oktet.ru
Type: application/x-gzip
Desc:
URL: <http://lists.rtems.org/pipermail/users/attachments/20021011/c4d81cf3/attachment.bin>
