as, cc, ld ... native or cross compiler? crt0.o?
    Ralf Corsepius
    corsepiu at faw.uni-ulm.de
    Tue Oct 15 03:47:09 UTC 2002
Am Die, 2002-10-15 um 02.48 schrieb Tito Costa:
> Joel Sherrill wrote:
> > Ralf Corsepius wrote:
> >>>configure:918: checking for executable suffix
> >>>configure:928: cc -o conftest  conftest.c 1>&5
> >>>cpp: -lang-c: linker input file unused since linking not done
> >>>ld: cannot open crt0.o: No such file or directory
> >>>By the way, lines 918 and 928 of the configure script do not correspond
> >>>to the ones reported in the log. Actually I searched "conftest.c" in
> >>>configure and I didn't find it.
> >>It seems to me that your toolchains' installation might be broken.
> > Since this is a Solaris host one has to ask:
> >   + Do you have a native compiler installed?
> >   + Is your native compiler gcc or SunCC?
> I have gcc installed. as and ld are the ones from SunCC; I checked
> sunfreeware.com to download a new version of gcc, but they say that "it
> was compiled to use the SUN assembler and loader usually in
> /usr/ccs/bin", i.e. the same as my current gcc installation. Maybe
> that's the way it is supposed to be for Solaris.
> as, ld, cc1 point now to the native ones as you guys suggested. RTEMS's
> configure script fails because it can't find a crt0.o file.
> I don't have any crt0.o on my computer. But I do have libc.a and other
> files called crt1.o crti.o crtn.o
> Is it supposed to be included in binutils? native/crosscompiler? where
> do i get a crt0.o?
The first core question to clarify is: Is your native toolchain functional at all?
Are you able to compile and run "hello world"?
> May I ask why if I want to compile for my target, the native as and ld
> are to be used?
You'd have to ask Sun. All I can say, you are required to have a
functional native toolchain (it doesn't even need to be gcc).
Ralf
