Unix Test Port
Ralf Corsepius corsepiu at faw.uni-ulm.de
Fri Oct 11 04:17:41 UTC 2002
Am Fre, 2002-10-11 um 01.38 schrieb David Dudley:
> One more question-
>  I'm finally getting around to looking into producing a port of rtems to the
> ATmel AVRmega chipset.  Looking on the website, I see that the documentation
> on the site is 2 years old, or so...  Is that the documentation I should be
> going from for producing a port based on the 1007 snapshot, or should I be
> using something else?
Using the most recent snapshot is the preferred way to go.
The current docs are included inside of the doc subdirectory. Use
--enable-docs to enable building them.
Ralf
