Unix Test Port
Fri Oct 11 11:13:03 UTC 2002
Ralf Corsepius wrote:
> Am Fre, 2002-10-11 um 01.38 schrieb David Dudley:
> > One more question-
> >  I'm finally getting around to looking into producing a port of rtems to the
> > ATmel AVRmega chipset.  Looking on the website, I see that the documentation
> > on the site is 2 years old, or so...  Is that the documentation I should be
> > going from for producing a port based on the 1007 snapshot, or should I be
> > using something else?
> Using the most recent snapshot is the preferred way to go.
> The current docs are included inside of the doc subdirectory. Use
> --enable-docs to enable building them.
I agree 100% with Ralf.
Note that the Porting Guide in conjunction with the existing ports
should be very helpful to you.  And don't be afraid to ask questions.
Start by compiling and using one of the other ports on a simulator so
you will have it as a point of comparison.  The mips, powerpc, or
sparc simulator BSPs I mentioned earlier this week are VERY helpful
when you want to compare behavior.  SOmetimes you want to see what
the state of RTEMS should be at a particular point in a test or
during the init sequence and that is VERY VERY useful.
> Ralf
