Web Server Patch
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Apr 10 16:53:02 UTC 2003
Mike Siers wrote:
> Hi All,
> I grabbed the latest source tar ball from GoAhead and got it
> working under RTEMS. I am assuming that it is version 2.1.4
> since this was the archive name (source code still says 2.1.3).
> The following URL is the release notes from GoAhead.
> http://data.goahead.com/Software/Webserver/2.1.4/release.htm
> I have only done a minimal amount of testing (i.e. the network
> demo program works fine). Please try this out and let me know
> if it works. The patch needs to be applied on the
> c/src/libnetworking/rtems_webserver directory.
I have merged this to the trunk (not 4.6 branch) and will commit
it once I have compiled it.
> I would also propose a small API change. I would like to
> have the function rtems_initialize_webserver() take one
> string pointer as a parameter. This would be the default
> directory for the web server files. If the parameter is
> NULL, then the server would use the root directory as the
> default. This change is not in the attached patch.
I do not have a problem with this patch if you submit it. Any
documentation
in the networking guide should be updated to reflect this.
> Mike Siers
> httpd.patch.bz2 Type: unspecified type (application/octet-stream)
> Encoding: base64
> Download Status: Not downloaded with message
joel at OARcorp.com On-Line Applications Research
