Ethernet support
Joel Sherrill
joel.sherrill at OARcorp.com
Sun Aug 3 16:00:21 UTC 2003
Madhu Raju wrote:
>>===== Original Message From Joel Sherrill <joel at OARcorp.com> =====
>>Madhu Raju wrote:
>>>Hi,
>>>I have a DY4 SVME board.Right now I am downloading an application onto the
>>>board through a serial port connection.How can I download it using ethernet?
>>>So that I could download it faster..
>>>Thanking in advance,
>>>Madhu
>>The simplest way would be to use the ROM monitor provided with the board
>>to do it. Does it have a TFTP client or any commands to boot from the
>>network?
>>I know that the Motorola, Vista SCORE603e and Radstone boards could
>>do this.
>>--joel
>I dont think the powerpc monitor has any commands to do this.Any other way?
Write a simple RTEMS program that you burn into the Flash on this board
that downloads
into memory. I believe that Eric Norum has had to do something similar
on a board he uses
so he might have some code to start from.
>Thank you,
>Madhu
