Online documentation
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Aug 14 13:01:34 UTC 2003
Angelo Fraietta wrote:
> I am currently in the process on writing up my thesis and am referencing
> the online documentation
> For example, I am looking at
> 22.8: Driver Address Table
> and would like to make just a reference in this case to the C Users
> guide. It would seem that that the driver address table is a just a
> chapter in this document set.
Yes.
> Will these chapter numbers change in the future or are they fixed in stone?
Well I am not Moses and nothing is set in stone but they haven't changed
in years and I don't see them changing now at the Chapter level.
> Would you be able to write the chapter numbers, and sections alongside
> the links instead of / as well as bullets so I can easily navigate to
> the appropriate sections using the chapter and section as a reference?
I personally don't know how to make the texinfo -> html tool we are
using do this. But the source for it is in doc/tools/texi2www so
if you want to tinker with the way it generates the top level
index.html, you are certainly welcome to do so. It sounds like a
nice feature.
The tool already prints the section numbers on each section and
subsection so you should only be talking about the section of
code that generates the index.html.
I have edited and augmented this tool in the past and it really
isn't that hard to edit. It is in perl and fairly straightforward.
joel at OARcorp.com On-Line Applications Research
