Where can I find cpp0?
Ralf Corsepius
corsepiu at faw.uni-ulm.de
Thu Aug 21 14:45:06 UTC 2003
On Thu, 2003-08-21 at 15:53, Leon Pollak wrote:
> Hello,
> First of all I must thank Joel and Ralf for the help. After "clean" redoing
> of everything, my last problems were solved. As my experience shows, it is
> better to delete the build directory content before rerunning configure
> script.
Just a comment:
What you say is true wrt. structural changes of source trees
(Adding/Removing subdirs, Makefile.ams, configure.acs etc.)
Autoconf and automake have problems in coping with such kind of changes.
> Deleting only config.status/log does not always help.
> Now, can somebody tell me where must the file cpp0 be?
# rpm -qf /opt/rtems/lib/gcc-lib/powerpc-rtems/3.2.3/cpp0
powerpc-rtems-gcc-gcc3.2.3newlib1.11.0-0_rc_0
> I downloaded the
> precompiled tools for powerpc (rtems-base, powerpc-rtems-gcc and
> powerpc-rtems-c++) on Linux. But when the build process came to librtems++ it
> said:
> powerpc-rtems-g++: installation problem, cannot exec `cpp0': No such file or
> directory
> gmake[3]: *** [o-debug/rtemsEvent.o] Error 1
This is a gcc internal file and is supposed to be found automatically
when calling powerpc-rtems-g++. If it doesn't, this would indicate a bug
in gcc.
You may want to check powerpc-rtems/c/<BSP>/librtems++/config.log for
details about what may go wrong.
Ralf
