Question about _init, _fini
    Bill Gatliff
    bgat at billgatliff.com
    Thu Aug 21 21:49:44 UTC 2003
Mike:
They're part of gcc's startup and shutdown processes, defined in
crtbegin.o and crtend.o.
They're functions; declare a do-nothing version by the same name, i.e.:
void _init(void)
... and you should be good to go.  You could also wander around in gcc's
source code and see what they do, but if I recall correctly, they aren't
needed in bare-bones setups.  :^)
b.g.
mikeci at acm.org wrote:
>>Quite likely yes.  Look for the .init and .fini sections of a linker
>>script for another bsp using a processor similar to yours- if you're
>>using a MIPS, have a look at the MongooseV's link script, you'll find it
>>down in the bsp directory.  WHile you're at it, you might want to check
>>the other sections too, linker scripts evolve and sometimes
>>leave bsp's behind.
>>Gregm
>Hi!
>Here is what I tried:
>1. Add a new section:
>.init :
>     KEEP (*(.init))
>and similar for .fini
>This gives me a linker error stating that _init and _fini are undefined.
>If I add
>.init :
>     PROVIDE (_init = .);
>     KEEP(*(.init))
>linker doesn't complain, but program generates an exception. My question
>is where are those two symbols defined, and how to link the code which
>goes with it?
>If I check the memory map, it seams that no code is linked neither for
>_init nor for _fini.
>Regards
>Ivica
Bill Gatliff
Professional embedded GNU training.
