Question about _init, _fini
gregory.menke at gsfc.nasa.gov
Fri Aug 22 11:53:45 UTC 2003
Oh yeah, I forgot about those. Examine the bsp_specs files located in
the two bsp directories, and add the crtbegin.o and crtend.o to your version.
Gregm
Bill Gatliff writes:
> Mike:
> They're part of gcc's startup and shutdown processes, defined in
> crtbegin.o and crtend.o.
> They're functions; declare a do-nothing version by the same name, i.e.:
> void _init(void)
> .... and you should be good to go. You could also wander around in gcc's
> source code and see what they do, but if I recall correctly, they aren't
> needed in bare-bones setups. :^)
> b.g.
> mikeci at acm.org wrote:
> >>Quite likely yes. Look for the .init and .fini sections of a linker
> >>script for another bsp using a processor similar to yours- if you're
> >>using a MIPS, have a look at the MongooseV's link script, you'll find it
> >>down in the bsp directory. WHile you're at it, you might want to check
> >>the other sections too, linker scripts evolve and sometimes
> >>leave bsp's behind.
> >>Gregm
> >Hi!
> >Here is what I tried:
> >1. Add a new section:
> >.init :
> > KEEP (*(.init))
> >and similar for .fini
> >This gives me a linker error stating that _init and _fini are undefined.
> >If I add
> >.init :
> > PROVIDE (_init = .);
> > KEEP(*(.init))
> >linker doesn't complain, but program generates an exception. My question
> >is where are those two symbols defined, and how to link the code which
> >goes with it?
> >If I check the memory map, it seams that no code is linked neither for
> >_init nor for _fini.
> >Regards
> >Ivica
> Bill Gatliff
> Professional embedded GNU training.
> bgat at billgatliff.com
