Heap Allocation problem
Cedric Aubert
cedric_aubert at yahoo.fr
Wed Aug 27 06:36:07 UTC 2003
--- Joel Sherrill <joel.sherrill at OARcorp.com> wrote:
> Cedric Aubert wrote:
> > Hi
> > I have solve my problem by have more memory in the
> > workspace area. I don't understand why because the
> > efi68k (same cpu) have the same size than my
> board.
> The memory allocation to heap and rtems workspace is
> done (on m68k BSPs) based upon some variables in the
> linkcmds if you have used the shared
> bsp_pretasking_hook
> like most of the m68k BSPs. If you don't get those
> variables right, then your RAM is not properly
> reflected
> into the heap size, etc.
Ok I will have a look later, I am base on
efi68k with a modified efi68k linkcmds with
the bsp_pretasking_hook
> > But now I have some trouble in function
> > rtems_io_register_name. I don't really understand
> > how termio works but I will take a closer look.
> It could ahve run out of memory. What test are you
> debugging with?
I try to debug with hello_world test. For the moment
I try to have correct memory initialisation with
a console (68681) with termio support.
> > A general question does it mandatory to have a
> imfs
> > with rtems ?
> If you use the console device, then yes it is
> mandatory
> to have the miniIMFS or IMFS. The miniIMFS provides
> device node support. RTEMS uses device nodes like
> UNIX and that requires a minimal filesystem.
That what I think, because I haven't made any imfs
and mknod hang during the shared console_initialize
function !!!!
> > Thanks a lot
> > Cedric
> > PS : Does anyone known some french firm that have
> > RTEMS support for customer like me :-) ??
> I know of people who would take RTEMS consulting
> work in
> France but for support in the traditional sense, I
> think
> OAR is the only one offering it.
Can you give me contact with those consulting people
> For consulting that involves more on-site
> development, OAR
> has some standing arrangements with people in other
> parts
> of the world.
Ok
Thanks
Cedric
> --joel
> > --- Cedric Aubert <cedric_aubert at yahoo.fr> wrote:
> >>Hi,
> >>I am doing a BSP for a 68k board and I have some
> >>trouble
> >>in the _Heap_Allocate function. My board go to
> >>Internal_Error_Occured fucntion.
> >>In fact in _Workspace_Allocate_or_fatal_error
> >>called by User_extensions_Handler_initilisation()
> >>called by rtems_initialize_executive_early(), the
> >>function Internal_Error_Occured is call because
> >>_Heap_Allocate return NULL. It's seem to be the
> >>second return NULL of this function. I don't
> >>understand
> >>why.
> >>Does anyone have had a similar problem during
> >>coding a BSP ????
> >>Thanks a lot
> >>Cedric
> >>__________________________________
> >>Do you Yahoo!?
> >>Yahoo! SiteBuilder - Free, easy-to-use web site
> >>design software
> >>http://sitebuilder.yahoo.com
> > AUBERT Cedric
> > SDEL Controle Commande
> > rue Nungesser & Coli
> > 44860 St Aignan de Grand Lieu
> > E-mail : cedric_aubert at yahoo.fr
> > Http : http://www.controle-commande.sdel.fr/
> > Do you Yahoo!?
> design software
> Joel Sherrill, Ph.D. Director of
> Research & Development
> joel at OARcorp.com On-Line
> Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
