RTEMS SS-20030128 available
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 3 14:16:01 UTC 2003
Jack Cawkwell wrote:
> Joel,
> Thanks for that. I have been thinking, and wonder if the online cd-image
> was changing when you upgraded it to the latest snapshot? I downloaded the
> cd image recently (in January), over a week in several sessions, but
> before you launched the latest cd.
The contents of the directory are a a moving target. So it is quite
possible that somethings changed in the period of a week. I know that
just
prior to the snapshot announcement, I was populating the directory
with new tools. So it is very possible.
Once the release branch is forked, I expect it to slow down.
> Referring to the other thread about the build tools, I am happy with
> using the tools, I cannot think of a better way of doing it. But I have
> found
> it hard to impossible to get a complete set of working tools and RTEMS
> version. The cd image should solve this problem. I have multiple linux
> boxes and can have more than one build environment, so once I get a working
> version....
In case you didn't notice, I also cleaned up the snapshots directory to
move a lot of stuff into an "old" directory. We want to keep older
stuff
around but it doesn't need to get in the way.
> Jack
> joel.sherrill at oarcorp.com writes:
> >> Well I do feel guilty that I am not contributing by testing out the CD
> >> image.
> >> I cleared out all the old versions using commands like rpm -q -a | grep
> >> rtems,
> >> and then removing anything detected; I am pretty sure I removed
> >everything.
> >If you always use the RPMs, this will work:
> >rpm -e `rpm -qg rtems `
> >and just to be sure:
> >rm -rf /opt/rtems/*
