RTEMS SS-20030128 available
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 3 16:54:23 UTC 2003
Jack Cawkwell wrote:
> Joel,
> Well that explains things. I assume that you have good reasons for not
> leaving the old (working) CD version in place, while you make the new one
> somewhere else?
Yep. It eats disk space a gigabyte at a time. :)
> I am not sure how to work with this, could you provide and publicise a
> stable period when a cd download it going to be kosher? An 8 or 9 hour
> download is not something I can do on the spur of the moment ;-).
How about I try to build a "new tree" in a separate directory and then
swap the old and new? I could even go so far as to make "current-cd"
as a symlink to a cd-date. That would make it possible to keep two
images online. I don't want to keep N images online but 2 is OK.
When the next modifcation happens, I will try that:
--joel
> Jack
> joel.sherrill at oarcorp.com writes:
> >> Joel,
> >> Thanks for that. I have been thinking, and wonder if the online cd-image
> >> was changing when you upgraded it to the latest snapshot? I downloaded
> >the
> >> cd image recently (in January), over a week in several sessions, but
> >> before you launched the latest cd.
> >The contents of the directory are a a moving target. So it is quite
> >possible that somethings changed in the period of a week. I know that
> >just
> >prior to the snapshot announcement, I was populating the directory
> >with new tools. So it is very possible.
joel at OARcorp.com On-Line Applications Research
