Changing networking-related compile options per-bsp
gregory.menke at gsfc.nasa.gov
Wed Feb 12 21:44:32 UTC 2003
gregory.menke at gsfc.nasa.gov writes:
> Hi,
> I've been working on getting the MIPS .sbss and .sdata segments setup
> for RTEMS, so far I'm making headway, but due to the sysctl stuff that
> just got added to the link scripts, I'm running into some problems
> where some symbols get allocated to the .sbss/.sdata incorrectly. To
> fix it, I'd like to adjust a compiler parameter for the libnetworking
> related trees to suppress .sbss/.sdata for that code only- but it
> would be only for the MIPS bsp's.
> Is this a reasonable approach- or perhaps, how do other bsp's handle
> this kind of thing.
OK, sorry- I figured it out. The Mongoose at least seems to run OK on
RTEMS built with -G4. It looks like the user program should be
compiled with the same -G parameter- at least for the file that
includes confdefs.h
The benchmarks are running now.
Sorry to disturb...
Gregm
