The eCos, QNX, ChorusOs irq handling API
gregory.menke at gsfc.nasa.gov
Wed Feb 19 21:59:19 UTC 2003
Valette Eric writes:
> The one I prefer. I wrote it years ago and RTEMS one can be seen as a
> second iteration... API is at least still processor dependent :-)
> They have indeed added the void* argument, suppressed the isOn routine
> (probably because one can assume that irq is enabled if a vector is
> connected which is not always true?) and I would follow them...
I would prefer to keep the semantics of setting a vector and then
allowing the interrupt itself to be disabled- the RTEMS task interrupt
level provides a means of controlling the set of enabled interrupts on
a per task basis. Its not been useful to me yet, but I'd hate to
loose functionality in an enhancement.
Gregm
