RTEMS SS-20030128 available
Jack Cawkwell
J.Cawkwell at open.ac.uk
Fri Jan 31 08:08:54 UTC 2003
Has the cd image been tested? I mean, has anyone taken the cd image
and on a clean machine, loaded the rpms' and source and successfully
built RTEMS?
Cheers, Jack
joel.sherrill at OARcorp.com writes:
>A new RTEMS snapshot is available. I hope this is the last snapshot
>before a release branch is forked. It is available in
>ftp://ftp.oarcorp.com:/pub/rtems/cd-working
>ftp://ftp.oarcorp.com:/pub/rtems/snapshots/rtems/current
>A number of nits fixed, loopback network test added to samples,
>and BSD sysctl() interface supported for the TCP/IP stack. This
>allows the standard SNMP package to work with RTEMS. The BSP Howto
>has been updated to reflect use of automake and the Getting Started
>has the versions updated.
>A few of the Ada binding tests link and run now but the Makefiles
>need some magic before they all will.
>Feedback greatly appreciated. I am mentally setting a timer and
>if there are no bad reports, when it goes off the release branch
>is forked.
>FWIW I am not merging the API change to rtems_io_register_name.
>It will be a post release item.
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>Support Available (256) 722-9985
