RTEMS SS-20030128 available
Fri Jan 31 14:04:27 UTC 2003
Jack Cawkwell wrote:
> Has the cd image been tested? I mean, has anyone taken the cd image
> and on a clean machine, loaded the rpms' and source and successfully
> built RTEMS?
That hasn't been done by OAR yet.  At this point around here, it would
take doing a fresh install on a machine.  Even my laptop is polluted
in this sense.
Any feedback on this before we get to it would be definitely valuable.
--joel
> Cheers, Jack
> joel.sherrill at OARcorp.com writes:
> >A new RTEMS snapshot is available.  I hope this is the last snapshot
> >before a release branch is forked.  It is available in
> >ftp://ftp.oarcorp.com:/pub/rtems/cd-working
> >ftp://ftp.oarcorp.com:/pub/rtems/snapshots/rtems/current
> >A number of nits fixed, loopback network test added to samples,
> >and BSD sysctl() interface supported for the TCP/IP stack.  This
> >allows the standard SNMP package to work with RTEMS.  The BSP Howto
> >has been updated to reflect use of automake and the Getting Started
> >has the versions updated.
> >A few of the Ada binding tests link and run now but the Makefiles
> >need some magic before they all will.
> >Feedback greatly appreciated.  I am mentally setting a timer and
> >if there are no bad reports, when it goes off the release branch
> >is forked.
> >FWIW I am not merging the API change to rtems_io_register_name.
> >It will be a post release item.
> >Joel Sherrill, Ph.D.             Director of Research & Development
> >joel at OARcorp.com                 On-Line Applications Research
> >Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >Support Available                (256) 722-9985
