inw/outw on PowerPC in rtems
Till Straumann strauman at slac.stanford.edu
Fri Mar 21 16:34:28 UTC 2003
gregory.menke at gsfc.nasa.gov wrote:
>I'm putting together a 3c59x PCI driver for RTEMS, its at a point
>where I'm testing it now- but I'm having trouble accessing the card.
>I have the PCI side under control, but the chipset exists in io space,
>and the inw/outw functions don't seem to be doing the right things.
 inw accesses ISA I/O space. Unless your
BSP uses the same base address for ISA and PCI I/O space (plus: the
firmware/BSP
has to configure your card's base address consistently - PreP and CHRP
should
probably work), you'll have a problem.
I usually prefer in_le32() which gives you more control over the base
address.
Using in_le32() with a BSP defined base address makes your driver easier to
use on different BSPs.
The respective macros and inlines are defined in
libcpu/powerpc/shared/include/io.h
HTH
-- Till
>I'm about to start the search down into gcc/newlib/rtems and find
>them, but I was hoping someone might have a hint as to their location
>and status before I do so.  Any suggestions welcomed...
>Thanks,
>Greg
