bit scripts
Angelo Fraietta angelo_f at bigpond.com
Sun Mar 9 23:32:03 UTC 2003
First set of tests with ticker.
I went one stage further and downloaded the cygwin tools and built using
them also.
I also wrote down the GRUB parameters in case they mean anything).
These tests were done using a pc386 build of ticker in the samples.
Working from Eric Valette
Cygwin Build
Mac Build
Linux build
Grub Display
Ticker
0x100000: 0x1e958 : 0x2d74
entry = 0x10000c
0x100000:
0x1ec44 :
0x2e28:
entry = 0x10000c
0x100000:
0x1eb04:
0x2d74
entry= 0x10000c
0x100000:
0x1eb44:
0x2e28:
entry= 0x10000c
 Works
Exception 6
Exception 6
Exception 6
I believe I can effectively eliminate a problem with my tools as I have
used the prebuilt cygwin ones.
Also, there can't be a problem with my bootloader as the exe from eric
loads fine.
I am therefore stumped?
It might be interesting to see what a pc386 that works from cygwin or
OSX gives in the boot
Any suggestions as to what I should try next
BTW, I used the exact configuration given below for the cygwin build,
have rechecked the md5 checksum and then even re-downloaded the RTEMS
source and compared using a Hex editor.
Valette Eric wrote:
> Angelo Fraietta wrote:
>> I rebuilt the tools with the config you gave me, however, It still
>> does not work for me.
>> I have also built on OSX and it appears that they are identical.
>> The exception on ticker is 13
>> On Monday, I will do a full comparison to see how identical the OSX
>> and the Linux ones are.
>> Could I get the exact config you used for building RTEMS also?
> --prefix=/usr/local/rtems-ix86-dev-tools' '--enable-pos
> ix' '--enable-networking' '--enable-rdbg' '--enable-rtemsbsp=pc386' '--ta
> rget=i386-rtems'
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
    Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030310/6b5aeec3/attachment-0001.html>
