Need help with CPU_Context_Switch and ISR_Handler for mips32 processor
gregory.menke at gsfc.nasa.gov
Wed May 14 21:00:57 UTC 2003
Ivica Mikec writes:
> > Joel Sherrill writes:
> > > Ivica Mikec wrote:
> > > > Hi!
> Hi!
> In my opinion cpu_asm.S is seriously broken for any MIPS processor >
> mips1. Here is the cpu_asm.S which I modified. It still doesn't work. Can
> you take a look and give me directions on how to fix it. Most important
> functions are ISR_Handler and CPU_Context_switch. Main reason for this is
> SR_EXL bit in status register which must be set to 0 if one wants to
> enable interrupts. Originaly this was not done properly.
It might well be broken for non-mips1 processors, you may well be the
first to be testing it. __mips32 as a #ifdef test is incorrect. Use
__mips1 or __mips3.
What variation of MIPS are you using? I really must insist on knowing
this before I can be of any help.
Given you suggest SR_EXL as an interrupt enable bit, I infer you are
running on a R4000. Is this correct?
I have R4000 documentation which I'll use to help track down what is
going wrong, however I really do need to know what processor & bsp
you're using.
Gregm
