rtems-4.6pre5 building first time WITH Ada
Chris Sparks mrada at catalina-inter.net
Mon Nov 10 14:41:05 UTC 2003
So which version Redhat Linux should I be using?  Is there a way to use
Windows 2000?
Ralf Corsepius wrote:
>On Mon, 2003-11-10 at 06:08, Chris Sparks wrote:
>>Hi,
>>How does one use the RPM files to build RTEMS along with the patches?
>Get yourself the *.nosrc.rpms and rebuild them.
>http://www.rtems.com/onlinedocs/doc-current/share/rtems/html/started/started00039.html
>>I have pre4 and want to upgrade to pre5.
>??? toolchains for pre4 are supposed to work with pre5, except that they
>may contain fixes to bugs that have been discovered between pre4 and
>pre5.
>Anyway, this doen't have much to do with your libc-issue.
>Your host system (Which OS is it?) simply is incompatible to the system
>Joel uses for building the toolchains.
>Ralf
