Static section initializing
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Tue Nov 25 16:03:50 UTC 2003
Leon Pollak writes:
 > Hello, All.
 > 	Some time ago I posted the message about the problem with C/C++ start file
 > (crt0...) in mbx8xx derived BSP. The only reply I received did not help a lot
 > :-(( (sorry...), therefore I simply wrote my own routine which called ctors.
 > 	The problem is that I forgot about static sections and now I arrived to this
 > point. I also can write (copy) this code by myself, but it seems to me
 > already as an exaggeration...:-)))
 > 	So, I try again the same question to the list :-). As I followed the
 > _Thread_Handler execution it calls the _init() function, but this _init()
 > contains exactly 5 lines of assembler which do nothing.
 > 	The bsp_specs file is standard from mbx8xx and contains:
 > *startfile:
 > %{!qrtems: %(old_startfile)} %{!nostdlib: %{qrtems: \
 > %{!qrtems_debug: } \
 > %{qrtems_debug: } ecrti%O%s}}
 > 	What may be the problem?
 > 	Any help will be highly appreciated
IIRC, _init is empty because you don't have quite the right set of
system libraries in your link script.  I think you need to include the
crtbegin, crtend- which gcc generates.  Look at the motorola_shared
bsp's link script- last time I used C++ in RTEMS it handled the
constructors properly.
Gregm
