sparc-rtems-size
Mon Sep 8 18:14:35 UTC 2003
gregory.menke at gsfc.nasa.gov wrote:
> Fabio Degiovanni - Eicas writes:
>  > Dear Sirs,
>  >                 thank you very much for your answer, you have to
>  > apologize me, but I mistook the question. What happens to me is that the
>  > executable is smaller than what sparc-rtems-size returns.
>  > To explain better:
>  > -ls -l HISA returns 1869954
>  > -sparc-rtems-size HISA returns
>  >    text    data     bss     dec     hex filename
>  >  231488  183040 9806288 10220816         9bf510 HISA
>  > I understood well your explanation about the possibility that the output
>  > file is bigger than the sum of the .text, .data and .bss sections, but I
>  > cannot understand why  my output file is smaller than the sum of the
>  > ..text, .data and .bss sections.
> Most likely the .bss section is not included in the output image.
Correct.  And yikes!! You must have some huge arrays declared in that code.
> Gregm
