FW: FW: CYGWIN i386-rtems BSP pc686 Instalation promblems
Dwight Smith
dsmith at redwindgroup.com
Wed Aug 18 13:05:13 UTC 2004
> -----Original Message-----
> From: Joel Sherrill <joel at OARcorp.com> [mailto:joel.sherrill at OARcorp.com]
> Sent: Tuesday, August 17, 2004 4:06 PM
> To: dsmith at native-system.com
> Cc: rtems-users at rtems.com
> Subject: Re: FW: CYGWIN i386-rtems BSP pc686 Instalation promblems
> Dwight Smith wrote:
> > Try to run ticker.exe sample on a couple of pc's AMD Duron (800Mz) and
> Intel
> > Pentium 4 (2.8Gz) with following results:
> > Duron ticker.exe(pc386) runs.
> > Pentium ticker.exe(pc386) fails
I get a flashing console cursor "_" on middle-left bottom of screen.
> > Pentium ticker.exe(pc586) fails
same as pc386
> > Pentium ticker.exe(pc686) fails
> How does it fail? The primary differences in those BSP variants is in
> the use of different CPU flags to gcc. pcXXX where XXX < Pentium also
> uses the counter/timer for the benchmark timer driver where XXX >=
> Pentium uses the on-CPU cycle counter.
> > Dwight
> Joel Sherrill, Ph.D. Director of Research & Development
> joel at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
